My oven does not turn off. I had to unplug it to get it to turn off when I plug it in same thing its still on. Now I’m not sure if it is the ignitor or the valve assembly, or am I completely wrong and its some thing else some one please help.
Thanks in advance
Hi.
Check if the oven thermostat knob is not stripped or broken inside. if the knob is OK than most likely there is a bad oven thermostat.
You can check it for continuity in off position. If there is continuity - replace the thermostat.Do not forget to unplug the range.
The thermostat AP2623073
The knob AP3883028
Here are the breakdown diagrams and Replacement parts for General Electric JGBS23SEH5SS Gas range | AppliancePartsPros.com
Thank you. Post the results.
Simon.
Thanks for the advice I’ll check as the thermostat as soon as I get home .
