I set oven to heat and it will show the degrees and then flip back down to 100 degrees. I left it on and it finally went up to 180 degrees but no more. It has electronic dial but is a gas stove.
Try unplugging or shutting the breaker off to the unit for at least
an hour then check the oven.
