I HAVE A GE GAS OVEN THAT ONLY THE BROILER BURNER WORKS. THE
BOTTOM BAKE BURNER WILL NOT IGNITE. IS THIS A FIX FOR A HANDY PERSON. THANKS FOR ANY HELP?
Remove the bottom drawer, disconnect the Bake igniter wires and check the igniter for continuity. Replace the igniter if the circuit is open.
This job is not too difficult to do it yourself.
- The part number for the Bake igniter is AP2014008
Here are the break down diagrams for the GE range Model JGBP90MEA1BC
