should I be able to see a flame thru the right lower access door when dryer is on? Because there is no flame visible.
Yes, the flame should be visible as well the glowing igniter prior to the gas ignites.
The first thing I would do is check the igniter for continuity and inspect the igniter mounting clip.
Here are the breakdown diagrams and Replacement parts for GE DDG7286MAL | AppliancePartsPros.com
