GE Gas dryer timer not working
Brand:GE
Model Number:GTD42GASJ3WW
Main Symptom: Timed drying not working
What happens & when: timed dryer worked. Then I replaced the burner assembly and I think a wire may have popped off. I opened the controls on top and see there is a black wire with a yellow stripe. But there are numerous open terminals. Does this wore need to be attached? If so where?
Looks like it goes to TX on the timer control.
31-16924 GE GTD42GASJ3WW Dryer Mini Manual.pdf (650.4 KB)
T and X are 2 different terminals which one does it go too? Thank you for your help
The black wire with a yellow stripe goes to terminal X like in the wiring diagram I sent you!
GTD42GASJ2WW 31-16924-Mini-Manual-36157.pdf (648.6 KB)
The black/yellow wire goes to terminal X on the timer
