GE Front Loading Washer
Brand: GE
Model Number: GFW655SPVDS
Main Symptom: Machine stops running 3 - 4 minutes after it starts. Then makes the same sound as it does after an actual cycle is complete
So, it fills, starts washing and then stops? Does anything move? Basket, agitator?
it starts to fill with water, but does not completely fill. Basket\Agitator Move. Then it stops and makes the ding sound that it always makes when it is complete. As of now, i have it unplugged. if i plug it in it sounds like it is draining water, but there is no water and this is happening with the door wide open
it sounds like it is in a flood mode. It thinks there is too much water in the drum. You may be looking at the pressure switch or main control. I would lean towards the control, WH22X37840 Washer Main Control Board | Genuine Ge OEM In Stock
Following up. Replaced he Main Control Board. same issue. And now water is staying in the drum and not draining
Can you get it to go into a drain mode where the pump comes on?
I don’t think. After we replaced the Control board, we ran it. it went for about 3 minutes, dinged like it completed the full wash cycle, which is what was happening last time, but the there was not water left in the drum. now water is in still sitting in the drum 12 hours later
Was this a board that had to be programmed? I am assuming it programmed correctly? I believe the pressure switch is on the control board? The board should have take care of any pressure switch issues and control board problems. I don’t have a tech sheet but there should be a way to put it into diagnostics and get an error code.
I did not do any programming. the board was installed and we tried to wash. is there a step i should have taken after it was installed?
I guess the board you put in is the parts number above as your model number is missing a digit.If so here is the instructions. Post the complete MODEL Number would be nice though.
WH22X37840.pdf (173.7 KB)
Did it come with programming instructions, if not, it may be that it has already been programmed. Go to Google, put in your part number and add programming instructions. Use #3 as your personality number. See if that helps.
no it did not. ok. programmed it with #3. tried to run again. went for 3 minutes \ stopped \ and now is flashing cancel on the LED Screen
and. I found the document from the first time we had to repla7 ce the control board. It said i should have used Personality #9. So i re did it. Ran the rinse and spin cycle. water was going within 3 minutes the led screen is now saying H20 Supply
