GE front loading not draining properly
Brand:GE front loading washer
Model Number: GFW655SSV0WW
Main Symptom: WONT DRAIN ALL THE WAY
What happens & when: water will not completely drain and the agitator keeps getting off balance so clothes are not spinning to damp and remain saturated. There was a bunch of standing water left in drum so I drained the front drain and then washer started to randomly drain on its own. I put a quilt back into the drum for a rinse and spin cycle. Most of the water drains out but not all the way and spin is on max but is not doing max spin, so I thought I fixed the issue but it only worked a little bit..
Either you drain pump is going out or there is a restriction somewhere in the drain system. It should always drain all the water out. It will not spin if it detects water in the tub
So I drained the water from the front of the washer, however being the newbie that I am, I got water all over the laundry room. Could I take the back panel off and drain the washer just as successfully from the back hose? Or do I have to drain from the front again?
If you can get to it from the back, sure. Especially if it is on a pedestal.
