I’m hoping to get some help troubleshooting my washer problem, so here goes…
The last couple weeks my washer has stopped intermittently (it only happens sometimes) mid cycle. It stops at different points in the cycle: some times it’s after the wash cycle (where it does nothing), other times it gets stuck in what sounds like the drain cycle (where it drains and drains and drains). Advancing the cycle knob a little bit returns the washer to normal operation. It appears to only happen in the cottons cycle; the quick wash cycle works fine.
I was pretty sure it was the timer knob, but then I read a bunch of stuff on the internet about clogged drain filters causing washers to stop working. My drain pump doesn’t have a filter, but I removed it and the rubber manifold that connects the tub to the drain pump and cleaned them. OH MY GOD THAT WAS NASTY! There was black slime and hard water deposits and it smelled like a sewer, but I put it all back together and the problem persists.
So my question is: is there any more troubleshooting I need to do before I spend two bills on this? GE WH12X10157 Timer-Wash - AppliancePartsPros.com
