GE front loader pressure switch adjustment
Hello, can anyone tell me which screw I should tighten on the pressure switch to make my washer use more water? There are 3 larger screw with star shaped heads and 2 smaller screws with flathead heads. Please see below picture…
pressure switch.jpg (7.4 KB)
I don’t think this is an adjustable switch, as water level is pre-programmed and is determined by the load.
Your switch may be faulty and you might try replacing your switch, but even then that might not help. GE has basically taken a simple procedure and complicated the dickens out of it.
Thank you for your reply. Are you saying this particular switch is not adjustable? I know other people with different models have tightened a screw on their pressure switch to achieve more washing and rinsing water.
Thank you again!
I was wondering if you ever figured out a solution to adjust it because I have the same problem with the same switch.
