Ge Front Load Washer Won't Wash
The washer will only fill with water and drain during any given wash cycle. also pauses during several times during any cycle.
I have tried reset the control panel ( it comes up 04 when i go into t01). Also had an error E22 during test mode t02, which I cleared.
During test mode t06 the display stayed on E and the tub filled and never emptied of water. Unfortunately, I tried to get out of test mode to “drain and spin” the water out and the door unlocked, so you can imagine the rest.:mad:
Test t10 seemed to work fine and I never got to t11.
There are no clogs in any of the hoses or in the filter. What should i try next?
The pressure switch hose needed to be replaced. (part cost $5.90). Total service cost was $196.24. The pressure switch could not work properly, due to the hole in the hose. So the washer was filling up with too much water and then draining. The tech says the hose could have frayed because of an unbalanced load that caused the washer to rub against it and cause the hole. This is my second repair on this washer. What a crock.
I have had this washer less than 2 years and have gone through a gasket (replaced myself-part cost $125-$150).
I am considering getting the service warranty.
