GE Front load washer Fails - error E46
My GE Front Loading Washer WCVH6400JWW hassled failed.
Washing machine will tumble but not spin and any cycle gets interrupted early and machine pumps water out.
I went into test mode and got error E46.
The pressure switch and hose seem to be fine (no holes in pressure hose). Test T06 completes successfully (machine fills to Foam, Main, and Overflow Levels then pumps out to E). Checked pump and hoses for clogs - all clear pumps water out.
Test T10: tub tumbles but only in one direction (does not alternate directions as indicated in the service manual.
Test T11: pump starts but tub does not spin at all (shows 0 rpm). Will not start spinning just stays at zero.
I tried re-programming the control board in Test option T01 but there was no change.
Any ideas of what the reason is?
Darek
I’m having same issues did you get yours figured out?
