GE Front Load owners manual
Got home with two dryer manuals and no washer manual. Need to know where the filter is located and how to get to it. Have a musty smell?
Larry
Since you did not post a model number we can only give you the generic answer, which is to remove the bottom panel and clean out the pump/drain area.
Model # WCVH6800JMS
See if this does not come close enough
http://appliancejunk.com/ge/washer/31-9135.pdf
