Dryer sqeeks real bad…Tub seems to be loose in back because there is alot of movement up and down, side to side when not running???
Any Suggestions?
You need to look at the front drum glides and also replace the rear bearing. Most of the time the front glides will go out and cause the rear bearing to go out causing the squeling.
WE1M333 is the part number for the front glides and WE1M462 is the part number for the rear bearing. You are looking about $16 to fix yourself or $150 to have someone fo it.
