GE Fridge
I got this GE Fridge Freezer on bottom, it’s not cooling hardly so I found the compressor fan wasn’t working. I purchased a new fan and installed and it didn’t work either.
Before discovering the compressor fan was not working I took the freezer panel off to check evaporator and it was fine. At that time I didn’t unplug the fridge I just turn the temp setting to off and the defrost heater was on. Not sure if it was just the right timing or not. Is it possible for a fridge to be running and defrosting the same time causing the compressor fan not to run?
Model # GDS20SCSBSS
GE Profile fridge
Check your inverter ( compressor Electronic Unit)
Typically attached right next to the compressor and grey box… back of fridge
Part# wr49×10283 Depending on your fridge unit just a note, the part numbers may be different on the sticker attached to the unit,
Cost about $250 on Amazon , more at a dealer. It’s not hard to replace, few screws, and a few quick connect harnesses.
If your compressor and fan are not working, this is most likely the issue as to why your fridge and freezer are not cooling off.
