GE fridge water filter check valve leaking
Hi there,
I have a GE side-by-side fridge. I’m having a problem with the check valve above the MWF water filter. Basically, when I remove the old water filter, the check valve is leaking water.
Any solutions?
Thanks.
Hi.
Please provide the complete model number of the unit.
Thank you.
Simon.
The fridge is a GE GSS25XSRD SS
Hi.
The part your should replace is a filter head and tube AP7220294
Here are the breakdown diagrams and Replacement parts for General Electric GSS25XSRDSS Refrigerator | AppliancePartsPros.com
Thank you. Post the results.
Simon.
Wow. Thanks Simon.
I looked at the breakdown diagram but didn’t see how to install the filter head and tube. Do you have any other diagrams or manuel showing how to change that part out?
Thanks again.
Hi.
Remove the water filter, pull out the cover. The base should be attached by two screws. Use common scenes.I could not find any step by step.
Thank you.
Simon.
