I have a GE pss26sgpass fridge.
I replaced the dispenser control board because I did not have water through the front dispenser, and auger would not turn.
I then replaced the main board, still no water or motor auger movement.
I am not getting line voltage to dispensor water solenoid. I couldn’t see any voltage on the circuit board on the Solenoid or Auger pins (I read I should be able to read mains voltage between J7P9 and J7P3. I am reading 0.
Lights work on dispensor board.
Any Suggestions?
(Attached: pics front and back of burned old main circuit board)
