i have a GE side by side fridge model GSH25jftabb and the freezer section makes a lot of frost/ icing around the freezer are but the ice cubes are melting forming to big blocks which damage the ice dispenser. I need help troubleshooting this..
Also, the water is not dispensing well. i would hear a click after 4 to 5 seconds of good flow then it willl slow down significantly. i have changed filters 3 times andthe problem is still the same.. need help with this …:mad:
