Hi Denman, thank you so much for your help. I think with your help this will be diagnosed.
So I stuck a screwdriver in the manual timer control, and turned it. It made a bunch of little clicks, and then a bigger click. Right then, the fridge power dimmed a bit, but that’s all–everything continued as before: the compressor fan was on, the freezer fan kept spinning. Most importantly, I put my finger directly on the defrost heater element (the metal tube with a wire on each side, part 257, at the bottom of the freezer coils that are all frosted over) and it never got hot.
So I was unsure about how to check continuity from what you described. I unplugged one wire and put the voltmeter probe on it, and then put the other voltmeter lead on the heater lead, put it on low ohms, and the needle didn’t move it all (and I did check the voltmeter by touching the probes, and the needle spiked). So then I removed the heater completely and put the probes on both leads of it, and still the needle didn’t move at all. If the part is busted, shouldn’t it spike? Maybe if it’s busted it just stays there. I certainly didn’t get 20 ohms. I’m attaching a picture of how I tested it.
So I’m thinking either I did something wrong, or that heater is broken.
Your thoughts?
thank you in advance!
[QUOTE=denman;831529]Here are your parts, I think.
I cannot find info on the given model number but the below is for a BAWW not a BWW. I am assuming you just missed the A.
Parts for GE TFX20JRBAWW Refrigerator - AppliancePartsPros.com
[COLOR=“Blue”]It is not airflow (I don’t think)–we didn’t have too much in there.[/COLOR]
A defrost problem is actually an airflow problem. The evaporator fan cannot pull air through the coils so the air does not cool correctly. Also it screws up the amount of air that is pushed into the fresh food section.
[COLOR=“Blue”]–in fact, I think they stay on all day it seems.[/COLOR]
The compressor and fans running all the time is one symptom of a defrost problem so I think you are on the right track.
[COLOR=“Blue”]Also, the ice maker doesn’t make ice, but I’m guessing that’s because it’s not cold enough in there.[/COLOR]
Also correct.
[COLOR=“Blue”]So from my research it seems most people suggest it is the defrost timer, the temperature control, or the thermostat.[/COLOR]
Possible causes of a defrost problem is the defrost timer, the defrost thermostat or the defrost heater.
[COLOR=“Blue”]My question is (are, actually): if I stick the screwdriver in the defrost timer, turn it, should the fridge then turn off?[/COLOR]
Correct.
The compressor and fans should shut off, the defrsot heater should come on.
[COLOR=“Blue”]If so, then I suppose I just change the timer (is that correct?).[/COLOR]
Sort of correct. If the defrost heater comes on then you problem is the timer.
[COLOR=“Blue”]What else would you all recommend? [/COLOR]
Below is my standard blurb ob troubleshooting defrost problems, I just added info on the parts.
First remove the evaporator cover in the freezer so you can see the coils.
If they are heavily iced/frosted over then it is a defrost problem.
Do not let them de-ice.
If yes.
Manually force a defrost cycle by turning the defrost timer cam (Item 257 in Section 07) till the fans and compressor turn off.
There is usually a hole in the cover to let you do this without taking anything apart.
Now check the defrost heater to see if it is on.
Be careful you do not want to burn your fingers.
If the heater is on then the timer needs replacing, re: it is probably stalling during it’s rotation so is never getting into a defrost cycle.
If not on.
Unplug the unit.
Remove the wire for one side of the heating element (Item 230 in Section 04) from the wiring and measure it for continuity, usually around 20 ohms or so.
If the heater is OK
Remove one wire to the defrost thermostat (Item 240 in Section 04) and measure it, should be 0 ohms when frozen. Note that it opens just above freezing so must be frozen to check it. Also inspect it, if it is bulged at all replace it even if it measures OK.
If both the above are OK then odds are the defrost timer contacts are toast.
Best way to test this is a live test to see if you have 120 volts across the heater/defrost thermostat combo.[/QUOTE]
2013-10-04 16.39.22.jpg (76.2 KB)
