The water dispenser stopped all of a sudden dispensing water. Ther is no broken tube or anything. What could have done that
What happen when you depress the water dispenser lever?
Would it make any noise? Would anything work? Would the dispenser light dim?
Here are the breakdown diagrams and Replacement parts for General Electric ESS25LGMAWW Refrigerator | AppliancePartsPros.com
There is no noise at al. The crished ice and cibe dice dispenser work. The light does not dim at all
Locate the water line under the freezer door. Follow the instructions attached to the reply and test the water line.
Water is not dispensing.pdf (258.2 KB)
