GE Element Haliant 12 TRPL trouble shooting
Brand: GE
Model Number:PS960SL5SS
Main Symptom:burner won’t heat
When you’re trying to use that burner, does the control panel show that you’ve turned the burner on and you’re just not getting heat?
That is correct. The control panel shows ‘on’ and nothing happens with any of the three elements at any heat setting.
I’d like to know what part(s) to order from you. Is the infinite switch part of the replacement burner?
M. Walker
This model does not use infinite switches for the cooktop elements. This sounds like a bad cooktop control board AP6286249 from what’s been said so far.
https://www.appliancepartspros.com/ge-machine-control-relay-wb27x29202-ap6286249.html
