I have an old GE electric range that I am having problems with. The oven temp is not correct and it seems to be inconsistent. I think the problem is either the temperature sensor or the control board. How many ohms should the temperature sensor test at? I am getting 15 ohms when I test it. Is there a way to test the control board?
Thank you!
