GE Dual Wave II - seems low wattage now
It is old, but it is built-in with the oven.
Bcause it says dual wave, I am under the impression it has two magnatrons. I think I found the manual here :
Upper oven replacement parts for General Electric JKP67G*02 Electric range | AppliancePartsPros.com
I really am not sure.
  1. What is the original watt rating on this?
  2. It seems to take longer and longer to heat up a cup of coffee.
This makes me think it is slowly getting worse and worse.
3) Is there anything I can do? maybe clean the fan and what not on the inside?
Thank you in advance
Nick
A few years late for your question, but I have the original Care and Use Manual and it is 700 watts.
Thank you for the info!
:slight_smile:
