Ge dryer
does the heating element cycle off and on every 2 minutes
Yes the heating coil should cycle on/off.
Not sure what the timing should be as it depends on your temperature setting, condition of the machine and the vent system.
If it seems to be cycling more than normal then the first thing I would do is check/clean your vent system.
