The dryer heats but does not remove all the water from the clothes. It takes several drying cycles to completely dry the clothes. The drum runs and the heating element heats but does not remove the water from clothes. It may take 2 hours to dry sheets. Any suggestions???
Most likely the problem is an insufficient air flow through the dryer and/or the vent. Make sure the vent is absolutely clean all the way through the outlet. Disassemble the dryer and clean all air ducts inside. Check the blower wheel.
Here are the breakdown diagrams and Replacement parts for GE DBXR453EV1WW | AppliancePartsPros.com
