My GE electric dryer timer won’t advance in the automatic modes.(DRXR473EWOWW). I replaced the timer in a recent purchase from APP.com:(. The dryer dries in all modes, but the timer only advance in the timed drying mode which is OK, so it is usable. I see in the parts list a resistor and thermostats, but have no idea where to go from here. I’ve cleaned all the duct work front and back.
Yes I saw the model number just cannot find any info.
Does sound like it may be a grounded element, wish I had the wiring diagram.
At the end of an Auto cycle the unit goes into cool down to prevent wrinkling and shuts the heater off using a set of timer contacts.
Note: Some GE’s use dual elements so if one of them burns out you will stall have heat but no timer advance.
Check the heating coil.
Unplug the unit and both wires to the coil.
Check it with a meter, should be around 12 ohms.
Then check from each side of the coil to the case/frame, both should be infinite ohms (open). If not the coil may have sagged or broken and is touching the case.
If you have a fax no. I can fax wiring diagram to you if that will help. the wiring diagram does show a inner and outer heating coil. My question is do I remove a side panel to get to the heating element?
If it happens to be a heating element, I’m not going to put another $200 into and old washer. I already made a mistake thinking it was the timer $80 dollar latter I’m no further ahead and a Repairman will probable be in the $400 range.. I just keep using it till the other heating element quits. thanks for trying
