GE Dryer Noise advice
Brand: GE gas dryer
Model Number:
Main Symptom: noise while running
GE gas dryer making a grinding noise while running. I’ve already replaced the Teflon glides on the front bearing (which appears to be in good shape) and replaced the felt. When I had the panel off I gave the blower in the lower left corner a spin with my finger and it rotated freely.
I have a video of the sound that I had hoped to post but cannot figure out how.
Model number will help!
GE model DHDSR46GE1WW
Came across my old post and thought I’d update it with the solution.
Previously to the noise developing I had replaced the belt. Apparently the belt I used was a little short. I sourced the correct size belt and it resolved the issue.
