GE Dryer Drum Rubbing
When we started our dryer tonight the dryer drum is rubbing and making a terible noise. Could this be a belt issue. I do not have the manual, is there a way to locate one?
Unplug the dryer and remove it to the yard if possible. Start here:
[LEFT]
Start here
[LEFT]
Older models need to have this clip removed(yer we3x75 goes there)
[LEFT]
we3x75 drum bearing
[/LEFT]
[/LEFT]
[/LEFT]
[LEFT]Remove the screws:
[/LEFT]
[LEFT]
Lift the front out yer way
[LEFT][/LEFT]
[/LEFT]
[LEFT]Inside the dryer:[/LEFT]
[LEFT] [LEFT][/LEFT]
[/LEFT]
[LEFT]Note location of non-resetible limit (if bad dryer will not run)
[/LEFT]
[LEFT]
[/LEFT]
[LEFT]A broken heating element:[/LEFT]
Broken dryer element (can easily be restrung)No need to buy the whole new pan!
[LEFT]
A good look at how dat belt oughta be if installed all propah.
GE Harmony Dryer Manual
[/LEFT]
