GE dryer does not heat. How to check heating element
Brand: GE
**Model Number:**PTD60EBPR1DG
Main Symptom: dryer will not heat
The first thing to check would be the thermostats to make sure that they have continuity. If they are good then move on to the heater and check to see if there is 240 vac. If there is but the heater is not coming on then this will be a faulty heater that would need to be replaced.
