I have a GE dishwasher that would not do anything,so I replaced the control board.When I put power to it the clean light blinked on and off and beeps also.I would try to reset it again and the same thing happens.Any helpwould be greatly appreciated.
Hello,
After you replaced the control board the dishwasher should go through the calibration automatically. The dishwasher will enter into the calibration mode when the unit is first powered on. The door must be closed and latched. You have to wait approximately 6 minutes for the second fill before canceling the cycle by pressing the start reset pad.
Did you do it?
I did not wait the 6 min.When i powered up and the clean light blinked on and off and beeped until I pressed a button the beeping stopped but the clean light still blinked on and off.I did this several times.
Possible it did not finish the calibration. Try to do it again from the scratch.
I tried it from scratch,does the same thing.Clean light flashes and beeps.I waited 10 min.Can you tell me how you put into service mode?
Sure. The procedure described in the attached mini-manual.
31-30477 (1) - GLD4500N10WW.pdf (582.7 KB)
