[quote=Bart1110;296788]In response to Joe’s reply, here are the symptoms. At the end of any wash cycle there is 1/2" to 1" on water left. Just by trial and error, we found the only way to get the water out, other than manually bailing, is to turn the main inlet water off and run a rinse cycle. After that there is no water left.
The dishwasher has never flooded or had water go into it if the dishwasher is not in use or off.
The drain hose is connected to the garbage disposal and the hose raises up higher than the inlet to the garbage disposal to create an air gap.
The water seems to drain OK when no new water is added. I haven’t removed the drain hose yet from the garbage disposal, but will do that next unless you have any other suggestions.
Thanks, Bart[/quote]
Bart,
Thanks for the update, the more information we have, the better we can help.
I have to agree with Denman,
You need to remove the sump cover, filter, and screen,
Carefully drain the remaining water in the sump and clean it out of any and all debris,crud,etc.
Disconnect the drain hose from the disposal, use a large bucket or trash can to collect the drain water.
Start the machine on a regular wash cycle and let fill and wash for a few minutes, then drain the unit ( you may want to do this a couple of times ).
Re connect the drain hose, re install the covers and screens, and test one more time.
Good Luck,
