GE Dishwasher will not cycle automatically
My GE Potscrubber Dishwasher will not cycle through the wash cycles.
-The knob is not stuck and the washer will cycle through if you turn manually.
-I checked the timer connections all attached and no corrosion.
-I do not have meter so can not check
-I checked the water and it appears hot
-The washer will cycle through the Heated Dry cycle and dries appropriately?
Can it be anything other than the timer? I have located timer on the internet for about $75. Washer is old but I do not want to replace if I can fix for under $100.
Any advice would be greatly appreciated.
Roho,
Most likely the problem is a bad timer and you can buy it from Appliance Parts Pros for $68.45
Here are the break down diagrams for GE dishwasher Model GSD3610Z05AA
[QUOTE=Gene;55244]Roho,
Gene.[/QUOTE]
Thanks for the response and links Gene. I will let you know.
Gene
Works great. Thanks again
