GE Dishwasher Water Valve Replacement
When replacing the water valve on GE PDW8400 dishwasher, is there right way vs. wrong way to reattach the wiring harness to the water valve. I didn’t pay close enough attention when I pulled it off, and have some concern about putting it back incorrrectly, or does it matter? The wiring harness has three wires running into it. One is white with a red stripe, and the other two are yellow. The two yellow’s run into the same side on the clip, opposite of the white/red wire.
It does not make a difference as the valve is 120 volts AC.
Thank you sir.
