when it is turn on it takes in water but does nothing afterwards, i.e., the motor does nto run, then I smell like motor is burning so I shut it off immediately.
Sounds like motor is bad; is it right? where can I but the motor?
Vincent
any instruction as to how to remove old motor and replace with new one ?
Most likely the pump & motor assembly has to be replaced. You have to remove the dishwasher from the cabinet. The new pump& motor assembly comes with the complete installation instructions.
The part number for the pump & motor assembly is AP2616850
