GE Dishwasher Leaking
We just noticed that our GE dishwasher is leaking. It seems to becoming from under the appliance…and it is dripping from some tub/box that is yellowish in colour right in the middle of the machine…does anyone know what could be causing it and how I go about fixing it?? :confused: thanks so much!!! :slight_smile:
[FONT=Times New Roman][SIZE=3][COLOR=#000000]If it is leaking at the motor shaft the pump seal is bad. [/COLOR][/SIZE][/FONT]
[SIZE=3][COLOR=#000000][FONT=Times New Roman] [/FONT][/COLOR][/SIZE]
[FONT=Times New Roman][SIZE=3][COLOR=#000000]Sometimes it will leak from the rubber coupling above the motor and the water will run between the motor. It will look like it is leaking from the shaft so check that good. [/COLOR][/SIZE][/FONT]
[FONT=Times New Roman][SIZE=3][COLOR=#000000]This page will help with both GE Dishwasher Pump Leaking Repair Guide[/COLOR][/SIZE][/FONT]
