GE dishwasher leaking
Dishwasher leaking around drain solenoid, after rinse cycle.
The ones I have seen leaking in that area have needed a PUMP&MOTOR!!! The water is leaking between the Two, There used to be a seal kit available(not sure if it still is) If you do decide to replace the P&M, The new motor that you get is both quieter and longer lasting.:slight_smile:
