I have a 2017 GE dishwasher model GDF520PGJ2BB serial#GH701191B The dishwasher won’t start. When I use to open the door the lights would come on and beep once and now they don’t. So I shut the circuit breaker off to reset the unit and it worked for about a week. Now that doesn’t work. Now if I hit the start button the lights come on. After I hit the start button to make it run after a couple of seconds the start button light starts to flash and beep and it will not run. I thought it was door latch so I replaced it. That made no difference so I replaced the control board and still have the same issue. Looking for help on where to go from here?
did you get this resolved? we are having similar issues. we replaced the inner door for our GE Dishwasher, since the original problem was a leak at the seal. my husband pulled it all apart, put it back together and now there is nothing that lights up on the control panel. There wasn’t an issue with that before now. It is getting power to all the wires according to his electric meter. So, he went to the local Fox Appliance and replaced the electronic board, plugged it in and now the same issue. It does not turn on. HELP!
I have the same issue. I used to unplug the unit and plug it back in and it would start working again. Did anyone get any resolution for this?
