GE dishwasher installation
I bought a new Whirlpool dishwasher from my friend. He moved in and didn’t need this dishwasher. Upon installation, there was 3 open PVC holes. I capped one and hooked the other up to the drain hose. It worked fine, but the one open hole had a little water drain out of it. I have now capped this and the unit doesn’t drain completely. I have no idea how this unit drains! Any help with diagrams would be appreciated. I have checked for blocks, clogs, ect… The unit is otherwise in pristine condition. Thanks
Here is a parts breakdown.
Replacement parts for WHIRLPOOL DU810SWPQ4 UNDERCOUNTER DISHWASHER | AppliancePartsPros.com
Often if you click on the parts picture a new page will open with more views.
You can then click on these to expand them.
Here is a manual which may help
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/56e33eb0e839a7fa85256a8e00510938/$FILE/4322430.pdf
Here is an install sheet
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Installation%20Instructions%20-%208535436.pdf
And just in case you did not get one, the operators manual
http://shared.whirlpoolcorp.com/assets/pdfs/literature/User%20Instructions%20-%20W10130987.pdf
Not sure what holes you are referring to so hopefully the above will be useful.
thanks, that is exacetly what i needed. The two holes were explained in the diagrams. I guess they called them food collection ports.
