Dishwasher was working fine, then just stopped. The lights do light up when you press a select button, then when you turn the knob, it just has an electronic hum, but won’t start. There is nwater in the bottom and I can’t get it to drain??? Any suggestions on what part I need to order?
The motor is probably stuck. See this article: GE Dishwasher Motor Repair Problem | ApplianceJournal.com
Thank you for your reply, it was a diferent model, but using a screwdriver i was able to rotate the motor fins until it moved more freely and plugged it back in and presto, it worked. Bloody maaahvelous! Thank you. Terry.
Excellent! Just keep an eye on it for a few days, make sure the pump doesn’t start leaking.
Hi Just saw your posting and it worked for me too. However the it looks like my seal is leaking… How do I remove motor and pump to fix with rebuild kit??
Thank you
J-PO
This trick worked for me. It saved me from manually washing dishes today, and it bought me a few months before I buy a new dishwasher.
