It fills with water and the dial moves through the cycles but it doesnt run.
Remove the bottom panel and check if the motor makes a humming noise when it should run.
If it does, the pump & motor assembly has to be replaced.
If it does not, check for 120 VAC at the motor plug and post the results.
- The pump & motor assembly AP2616850
My dishwasher does not drain. Does it need the whole motor, that is a lot of money.
What is the complete model number of the dishwasher?
Does the pump run during the drain?
[quote=Gene;232983]What is the complete model number of the dishwasher?
Gene.[/quote]
The model #is GSD00X-66WA Ser#MM16971B Thank You very much
[quote=Ladytaz;233104]
It is very old, I think it is about 13yrs old. It was in the mobile home when we bought it. The mobile home was built in 97. The model #is GSD00X-66WA Ser#MM16971B Thank You very much
You did not answer this question.
[quote=Gene;233213]You did not answer this question.
Gene.[/quote]
ooops sorry, not sure. I know that when I was using it the dishwasher did not drain at all. It would just overflow. We have tried taking the catch and cleaning it, making it free of gunk. Hope that answers your question somewhat.
Thank You
I need you to remove the bottom panel, start the dishwasher and check if the motor will work or just will make a humming noise.
[quote=Gene;233227]I need you to remove the bottom panel, start the dishwasher and check if the motor will work or just will make a humming noise.
Gene.[/quote]
Ok I will do that! I will have to do it the morning and let you know thanks
