How do I remove dishwasher soap dispenser from inside of door panel?
Once I get that info, I will be placing order for new dispenser. (Door will not stay closed) I’ve removed the caked soap buildup from latch, but that hasn’t helped. Is it recommended to use liquid or powder detergent?
Thanks in advance.
RMW:)
ronald_wolf@comcast.net
What is the complete model number of the dishwasher?
Model #GSD6200J01BB
Gene, I look forward to hearing from you.
You have to remove the outer door panel and all screws around the dispenser assembly on the inner door panel.
- The part number for the dispenser assembly is AP3994610
Here are the break down diagrams and Replacement parts for GE GSD6200J01BB | AppliancePartsPros.com
