GE dishwasher constant tone; not working
We have a GE profile dishwasher that is toning constantly from the control board and non responsive. This is following a power loss.
Have done the following with no resolution:
  1. Replaced the main control board with new.
  2. Disconnected all plugs into main control board with the exception of power; still toning.
  3. 120VAC at power supply to board.
  4. Disconnected power (white lead) to all other components with exception of heater; still toning.
  5. Checked resistance to all components. Results as follows:
    Fan: 66 ohms
    Detergent module: 2100 ohms
    Drain pump: 16.6 ohms
    Heating element: 16 ohms
    Flood switch: open, no water present
    Water valve resistor: 1120 ohms
    Circ pump: 10 ohms
    Drain pump resistance is lower than on drawing, but does not seem bad; all others appear normal.
  6. Check door switch; function correct.
    Found one burnt strip on the keypad for a lighting diode; opened the circuit. Have not replaced the keypad yet.
At this point am considering ordering a new keypad and/or temp/turbidity sensor, but do not want to spend the money unless we think it will resolve the problem. Any suggestions would be appreciated. Thanks in advance for your help with this.
As a follow up for anyone who checks this thread, replaced the touchpad and the dishwasher now works. Ran through one complete cycle with no problems.
