Hi All, hope you can help me. I started running it yesterday, and I heard a clunking noise occurring at the same frequency. I thought that the water jets were hitting some unstable object. Emptied it and reran it, same noise. So I check the rotating arms. The top one is fine, but the lower one has play in it. To be more specific, it has vertical play in it, I can lift it about 1/2 in. Is that normal? I know that that is where the noise is coming from. Any help will be appreciated.
Hi.
Most likely it’s not the wash arm.
Check the filter sump #508 at diagram#1 and inlet sump#505 at diagram#4 for any small objects (Pits, bones,etc.)
Here are the breakdown diagrams and Replacement parts for General Electric GLD6860N00SS Dishwasher | AppliancePartsPros.com
Good luck. Post the results.
Simon.
[QUOTE=Simon / APP Team;735044]Hi.
Simon.[/QUOTE]
Hi Thanks, I don’t 505 on diagram 4
Hi.
Remove the coarse filter#502 on diagram#4. You will see the sump.
Simon.
