GE DHDSR46EE1WW Will Not Start
Brand: GE
Model Number: DHDSR46EE1WW
Main Symptom: Will Not Start
What happens & when: Initially Dryer Would Not Dry Clothes
Error Code (if any): None
Parts or tests already tried: Found Broken Heating Element, Broken and Shorted Closed Start Switch, Thermostat (Fuse), and Broken Belt Interlock Switch.
Replaced those components to correct lack of drying clothes and now it’s exhibiting NO START
I tackled this job to save my ailing mother $$$$
I have since tested every Switch and have continuity when depressed (if required)
I followed the Appliance Parts Pros procedures and came to the conclusion the motor was faulty. I replaced the motor and the motor will not activate. I went back through all the procedures outlined in the video and the motor will not activate.
Any help would be AWESOME!
Thank you!
Lawrence
Check the door switch and the idler spring switch, and recheck wiring.
GE Electric Dryer Minimanual 31-16093.pdf (81.7 KB)
I have that wiring diagram included with the dryer
Continuity through both switches when depressing and minimal voltage present
Thanks!
