GE Convection element replacement
My convection heating element started sparking during the last use and I confirmed by removing the protective cover today that there is a nice burned mark on the element. I would assume this means the element is bad, thus causing no heating when convection is selected (the fan still starts and normal heating works fine).
Assuming this is my problem, just looking to see if the element replacement is fairly straight forward and doable from the inside of the oven… or is it more complicated and require access from the rear (meaning this built-in unit would need to be pulled out)???
Thanks in advance for any help.
anyone???
