Brand:GE
Model Number: CFCP1NIY
Main Symptom: fan turns on clicks and stops. Gurgles, then clicks every 20 to 30 seconds.
What happens & when: It sometimes starts after several trys. If it doesn’t stay on, it loses temperature. I replaced the starter relay switch. That did not fix it. Although it is less frequent. When I catch it in this mode. I shake the refrigerator and it starts. It will run for 24 hours or more (sometimes days) before it gets stuck in this cycle. The digital refrigerator/ freezer temps go blank
Error Code (if any): no code
Parts or tests already tried: starter relay switch. (It rattles when I shake it. It did new.
Photos / video link: Quick Share
