I have a GE Built-In Oven (Model #JT910) that the Clear/Off button is not functioning. All other control buttons activate and work properly, including Clock, timers, Cooking Selections and temperature settings. When I push the Clear/Off button - nothing happens, ovens settings stay as is and no audible tone is heard. My question is do you think I need to replace the entire Touchpad and Control Panel Assembly (P/N AP2029580) or just the Electronic Oven Control/Clock kit (P/N AP2633043).
Note: getting tech info off the net is near impossible, GE likes to keep this a secret.
I would try the following cleaning/checking first.
Since I cannot provide pin-out info for the keypad it becomes difficult to check the keypad switches.
The likely culprit is the keypad/control panel but it is a bit of a crap shoot.
Connector Cleaning / Checking
Unplug the unit
Open it up
Clean the edge connector.
