Brand: GE Model Number: JGB720EEJ4ES Main Symptom: Broiler burner What happens & when: Broiler ignites then goes out then ignites up again and goes out. it keeps doing it. The glowbar stays on and bright the whole time ,
Using a multimeter, ensure the voltage from the control to the igniter is a constant 120VAC, and the voltage to the gas safety valve is in range at 3.2 - 3.6 volts. if these check out as in range you will likely need a new safty valve. WB21X33225 Valve Control Asm | Genuine GE OEM In Stock
