Hello , I have a GE PSB2201NSS GE Profile Advantium® Wall Oven Microwave, 220v
The other day the unit lost power - no lights were on the display. Based on research I read, the TCO had tripped so I bought a new themal fuse, installed it and I got power on the display to turn on.
However, right when the door is closed on the unit, the unit begins to make a humming/slight buzzing sound and is warming up on the inside of the machine without entering a cook time or pressing start/cook.
I tested it by putting some food on a plate in the unit and the food and bowl was very hot after maybe 10 seconds. The turntable was not spinning or anything, the microwave was just heating on its own.
Im not sure if it has anything to do with the door interlocks because the turntable is not even moving, its just heating very hot inside the unit without turntable movement and the sound is different than when you select a cook time and press start.
Im not sure what else to try, but would appreciate anyone’s input. I can provide additional information if it helps solve the problem. Thank you
