This is a convection oven and microwave in one. I love this oven, but I bought brand new 2009. It started not turning. I had a GE repair man out for another appliance and he told me it was more than likely the motor. He gave me the model number I needed, we ordered and replace it. It worked initially and then worked sporadic, now it’s not turning at all.
I have cleaned the wheels, the glass plate, etc. Did I get a defective motor from you or could it be anything else?
Had GE repair man out-he found that the shaft assembly had a crack in it; therefore when any weight it put on it, does not turn due to the slipping. I have ordered the part via AppliancePartsPros.com and hope this does the trick! that is an expensive service call for that being the issue
