Brand: GE
Model Number: Adora
Main Symptom: Error code 815
What happens & when: D/W did not operate. Error code 815. Replaced control board AND door switch. Re-set codes. Dishwasher now works properly but D/W beeps randomly when not in use. error code 815 still present.
Error Code (if any): 815
Parts or tests already tried: Replaced door switch AND control board
The 815 code for a GE branded machine usually references a communication error. This can be an issue with the door latch, the door latch wiring, or the control assembly. Start by doing a hard reset (kill the power to the unit for a minimum of 5-15 minutes). If the issue persists, check the door and door latch for proper alignment and operation. If it still persists check the wiring from the control (located at the dishwasher base up to the latch. If the issue still persists the issue is likely the control board and it would need to be replaced.
[AppliancePartsPros.com]
(Dishwasher: Troubleshooting Common Dishwasher Problems & Solutions)
